what is about symbol library in Design-vision?
link lib set it as set_link_library {* tsmc90.db}
that should do it.
(tsmc90 or whatever the name of your db file)
Hi Pavan,
Suppose, I have the netlist which was obtained on 180nm and if i have to convert to 90nm, Will link and target library work in DC.
I tried those, and i could not get the correct results.
Hi lohi
Actually it should work unless these two db files are from different vendors and they are very different...in this case your 180nm db file will be included in link library and your target library will be declared as 90nm db...
cheers
do you have other library files? if yes then you must be having the symbol library as well. you just have to figure it out. i can provide you with the file but that wont work for real fabrication purposes. you can use that file for simulation and understanding the tool though.
@Phoenix Pavan,
Is it possible to generate EDIF in Design Vision? After synthesis is done?
