renwl said:do you mean auto-routing like digital layout?
Fom said:As I understand ic5141, icc11241 and pdk should be enough.
But your schematic should be designed using PDK libraries.
I was going to use auto routing but I give up this idea during design stage. It is very unconvenient to optimize circuit that was designed using PDK library.
Fom said:I don't remember in full details.
It was impossible to put resistor value as variable and sweep that as a parameter during simulation. The resistor value should be a fixed number not variable.
Fom said:You can try, but the CDF paremeters set of PDK resistorcan be different from analogLib. I have to change every resistor value manually.
And I am not sure it is the only truble.
