enjunear
Advanced Member level 3
- Joined
- Dec 21, 2010
- Messages
- 960
- Helped
- 309
- Reputation
- 618
- Reaction score
- 303
- Trophy points
- 1,343
- Location
- USA, midwest
- Activity points
- 9,749
TY
I've tried measuring the loaded and unloaded voltage of a wall wart (maybe its a transformer type), and there was huge diff when measured unloaded. I don't know the theoretical reason, but practically i know it's because the wall warts are designed for that ampere rating. Please tell me theoretically why it happens. Do you mean there will be no problem in SMPS type(due to opto couplers-feedback).
Transformers have losses, like every real part (so do caps, inductors, diodes, etc). The following is an equivalent circuit model of a real transformer. The part inside the dashed lines is the ideal transformer (no losses, perfect at every frequency).
You can see that there are several resistive loss mechanisms inside a transformer. The R1 and R2 are primarily composed of the winding resistance (resistance of the wire used to create the primary and secondary coils). Rc is a parasitic resistance that can be thought of as the equivalent resistance of the magnetic material (you don't get perfect conversion from electric field to magnetic field, then back to electric field).
If you think about the unloaded and loaded cases, you can quickly see that as you draw current through R1 and R2, the output voltage will drop. This is basically the effect you are seeing.
