[SOLVED] Voltage Level Range Converter Shifter
I had thought about using the inhibit on the 4051 and tying that to the same switch that I am using for the 4066, so when I switch the 4066 for external CV in I am disabling the 4051.
Sure, this is fine, if you don't need the other 3 CV Channels [234] at the same time as the external CV.
BTW, I forgot to mention: For the 4066 pull down (R24) a 100kΩ resistor is sufficient.
Cheers, erikl
Hi erikl,
I won't need the other CV channels as I will be trying to replace them all with external signals, so the voltage shifter and 4066 switch circuit will be x4.
I couldn't decide between 10K and 100K. 100K sounds like it is the correct option but I wasn't sure.
Thanks for your advice
Martin
I'm updating this in case anyone else wants to mod their SX-400.
For some reason I got a faint high pitched sound in the background when I tried to use the inhibit on the 4051 so I decided not to use that.
I had to send the pull-down resistor for the 4066 to -5v. It wasn't working going to GND.
I left off the 100 ohm input resistors that the original single CV in had. The 4066 on resistance and the wires etc add up to around 40-60ohm anyway.
The whole system seems to work fine. I added a switch and LED to disable the internal circuits.
Thanks to everyone who helped. I couldn't have done this without you.
I will post the schematic for the Gate signals that trigger the playing of a note as well, when I get it finished.
Gate In schematic. Remember, you will need to insert dummy jacks into the original CV/Gate socket to disable the internal circuits.
