curious_mind
Full Member level 4
Hi FvM
It is surprising that I used *.cir model from analog devices for ADG1201 and it does not work. "does not work"means that I did not see any output pulses. I used existing model in LTSPICE and indeed circuit works right. I wonder what is the difference between these two models. Will this work in PCB? How to choose the op-amp. I want the output to be 1MHz. Accuracy can be around 1%
