Verilog HDL AES 128 bits ENCRYPTION DECRYPTION
Kaival_2934
Newbie
Newbie level 1
I am currently working on a project "AES 128 bits ENCRYPTION DECRYPTION", using Verilog HDL.
Now the problem I am facing is that while simulation- if i provide a plain text all zeros, it gets decrypted perfectly. But when i provide a big number like all ones in plain text, the decryption doesnt work perfectly i.e. i dont get the original plaintext. I tried with various plaintexts like for some i get the decryption perfect but for some i dont get the accurate decryption output.
I also cross-checked my logic, it is correct...
Can you please help me with this? What can be the solution for this problem?
First, you need a algorithm model to verify the function of verilog code.
So, you can find some c model from github, e.g. https://github.com/kokke/tiny-AES-c
You may even find some RTL implementation on github.
BTW, the episode talks about the basic verilog simulation enviroment:
Write your reply...
LaTeX Commands Quick-Menu:
