mahdiiust
Junior Member level 1
Hi
I designed a circuit with atmega8 for measuring a voltage and then if over voltage is occured a 12V relay will be on. but when the relay is on, the measured voltage reduced. I use LM326-2.5 as reference voltage on Aref pin.
what is the problem? Is it related to my PCB design? the schematic is below.
Thanks.
Thanks.
