crutschow
Advanced Member level 6
- Joined
- Feb 22, 2012
- Messages
- 4,524
- Helped
- 1,003
- Reputation
- 2,004
- Reaction score
- 1,146
- Trophy points
- 1,393
- Location
- Colorado USA Zulu -7
- Activity points
- 25,762
Yes, a switching power supply would have much higher efficiency and thus lower dissipation.Problem is power dissipation at 24Vdc/250mA, should decapitate
6W. too much high
Are you talking about switch mode power supply?
But note that switching supplies have a higher output noise level (from the switching process) so that could be a problem if you are trying to power sensitive analog circuits.
Also switch-mode supplies must be laid out carefully on a board with a very good ground layout (using a ground plane preferably) or they may not work properly.
