azwaa
Member level 1
- Joined
- May 21, 2014
- Messages
- 32
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 6
- Activity points
- 197
Okey ;
Thank you ;
Thank you ;
use IEEE.math_real.all;
use IEEE.math_real."ceil";
use IEEE.math_real."log2";
For the easy option, you need to just make everything the output length from the beginning.
something like this:
Code VHDL - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 type mult_array_t is array(0 to longueur-1) of signed(15 downto 0); type adder_stage_t is array(0 to longueur/2-1) of signed(Q'length-1 downto 0); type adder_tree_t is array(0 to log2(longueur)-1) of adder_stage_t; signal mults : mult_array_t; signal adders : adder_tree_t; ... --multiplies: mult_proc : process(clk) begin if rising_edge(clk) then for i in mults'range loop mults(i) <= ip(i) * C(i); end loop; --initial adders: for i in adders(0)'range loop adders(0)(i) <= resize(mults(i*2), Q'length) + resize( mults(i*2 +1), Q'length); end loop; --other adder stages: for level in 1 to adders'high loop for i in 0 to longueur/ (2**(level+1)) loop adders(level)(i) <= adders(level-1)(i*2) + adders(level-1)(i*2 + 1); end loop end loop; end if; end process; Q <= adders(adders'high)(0);
Doing this, the synthesisor can trim any unused bits.
1. ceil and log2 are part of math_real. The first line should already include it. In case of doubt review the library definition of your VHDL tool.Code:use IEEE.math_real.all; use IEEE.math_real."ceil"; use IEEE.math_real."log2";
2. the additional lines have wrong syntax
