D.A.(Tony)Stewart
Advanced Member level 7
- Joined
- Sep 26, 2007
- Messages
- 10,298
- Helped
- 1,868
- Reputation
- 3,741
- Reaction score
- 2,518
- Trophy points
- 1,413
- Location
- Richmond Hill, ON, Canada
- Activity points
- 64,908
he corrected it later
Hi
I m trying to drive a resistor (dummy) load rated 24V, 0.6A using a Infineon BSP295 N-MOSFET (Attached).
A power supply is used to provide power to the circuit. A 3.3V regulator rated at 0.3A is connected to the switch then to a voltage divider before connecting to the gate. When the switch is closed, a voltage divider gives 3V to the gate. The current drawn at the initial phrase goes up to 0.6A for about 5 secs, before slowly reducing to 10mA, as if the MOSFET is not conducting. This is happening consistently.
In another implementation, the 24V is connected to the switch, a voltage divider before connecting to the gate. The voltage divider gives 13V to the gate when the switch is closed. Again, the current drawn at the initial phrase goes up to 0.6A for a longer time of about 10 secs, before slowly reducing to 10mA, as if the MOSFET is not conducting in a consistently manner.
What is wrong with my controlling of the MOSFET?
Surely not.To get the MOSFET to operate as a switch, I read that it is best to operate in the linear region?
Klaus, you are talking about a bipolar transistor, not a Mosfet where the linear and saturated regions are opposites.You should operate the MOSFET as switch in saturation region.
