Using ADC n PWM to light up the LED dimmer - need help
i am doing ADC
I thought it was due last Monday.
I suggest you stop wasting your time online and start studying C
Which part of the code are you having trouble with?
Re: i am doing ADC
cos i quite urgent so i need u to tell mi the code is doing what. den from there i will slowly learn by myself
Added after 5 minutes:
i dunno the code is doing what.. jus tell mi first, can?
i am doing ADC
How's the studying going? The code is commented so it's not to tough to figure out.
Hint: The {} indicate a block of code.
PS "me" is not spelled "mi"
Don't they have electronic forums in Japan?
Re: i am doing ADC
jus tell mi the code tis code meaning unsigned int index=0, total_period= (unsigned int) 255*256, on_time=0; mean what? i dunno what is the meaning. is urgent
i am doing ADC
That line sets up your variable types and initial values
index = 0
total_period = 65280
on_time = 0
Re: i am doing ADC
can give more detail? explain more pls.. i really lousy in programming de
Re: i am doing ADC
but do u have the link of the website? i dun understand
Re: i am doing ADC
Please try basic tutorials:
Please try this ....
Regards,
Anand
Re: i am doing ADC
hvane yet.. i only done my ADC
Re: i am doing ADC
help help.. i be able to do everyting but i dunno i am corret anot
i am doing ADC
here,,,,
Dont pay attention to the UNIX.
Re: i am doing ADC
now my ADC code can read the value but the PWM i have no idea hw to test n do the coding.. any guide? or help mi
i am doing ADC
u can measure the wave duty of the PWM's output pin of the C8051.compare with your setting of PWM register
Re: i am doing ADC
the problem is i don't even know how to measure the duty cycle and how to write the code. i need some guide
Re: i am doing ADC
use oscillograph to mesuear.you must read datasheet and then write code.
Added after 21 minutes:
here is the application document
