USB to rs 232 Converter
rs232 usb schematic
I'm looking for PL2303 reference design, therrefore I'm posting to see. Thanks.
prolific usb to rs
mbyka said:
hi I buy this Product h**p://www.digitus.de/scripts/digdetail.asp?artnr=DA%2D70146 da-70146
driver h**p://www.services.digitus.info/data/download/treiber/da-70146.zip
but I can Not Work my LAptoop and by IC-prog jdm programmer
can you help me please?
What can I do?
hi byka,
im koordinat.ur driver should be set and u under windows>settings>control panel>system>hardware look at ur devices driver specs.and look at the advanced settings.from one of these u should see the vrtual port that ur usb is using for rs232.set it to the port u like and set the baud rate.then do these settings for ic-prog,jdm..
hope it works
ic tusb3410
MBYKA
I don't know the specs of your converter, but i think the main problem it's because the jdm needs the
+-12 V of a real rs232 serial port. maybe you should visit the kitsrus page and look the
DIY K149-BC programmer.
prolific usb to serial problem rts is inverted
However i am new to programming in VisualC#.NET.
Is there any Other (simpler) way in which i can access the COM port (read/write to XML device connected to it) using either Wndows Application (prefered) or Console Application!!
The "using System.IO.Ports" is not available in VS.NET 2003. Likewise the 'MSComm' control.
Please help.. thanks
driver digitus usb to rs232
Any one of you have a schematics for one RS232 to USB converter using TUSB3410. I need it for an Academic project.
cp2101 rs232 circuit
I'm trying to design a control system for my graduate project,
I'm very new to microcontrollers and microprocessors and have no experince.
Could any body please tell me how to start and any guide lines or advises.
digitus usb to serial converter driver download
wfang said:
I'm also interested in TI TUSB3410, anyone has done project with this chip?
I have done this project successfully. TI supports all documents and you just only follow the schematic that they provide.
driver adattatore usb seriale digitus
There's no code in the EEPROM, it just contains vendor ID etc.
You program the name you want to be displayed a the dilpg box in Windows every time you connect it to the USB port.
so, do you have sample program which can program in the EEPROM ? where is for PL-2303 IC's EEPROM.
Thanks!
schematic for convertor usb to rs232
you can also use software emulation using ATMEL AVR At90S2313 or ATmega 8 series
to make a low cost usb to rs 232. it is free and only support usb version 1.1 low speed.
for further information you can see at
схема pl2303hx rs485
How do i download the pl2302 schematics ? It says i am not authorized.
tusb3410 design schematic
why should we need USB to 232 Converter?
please reply for this
schematic rs232 usb
PL2303 is the best choice, is a very easy and cheap solution for USB<->UART.it can also need no eeprom!
so try PL2303, you will like it.....
See ==> www.prolific.com.tw
pl-2301 reference design guide
Texsas instruments TUSB4310 is easy and works OK.
dku-5 schematic
davorin said:
Just received free samples from TI...tusb3410 and tusb3210...
Hope I can tell you soon something about...though not working on windows (o;
Okie, the IC TUSB3410 is best i think so
I made the demo board and tested. The IC worked ok,and you can free download the VCP soft ware at www.ti.com
Best
schematics usb to rs232
has some mod.s
232 to usb schematic
Does anyone use VB6 programming using the Prolific PL2303 ?
What is the MSComm setting should i put ?
My programming speed slow down when using USB PL2303 compared
to Serial. This should not be the case as the USB should be faster compared
to serial ?
Can anyone help ? thanks
Best Regards,
i
dku-60 cygnal cp2101
hı ı buy a erıcson data cable 3$ and ınsıde pl2303 and cut cellfone cable take rx pin 5v and groud connec to gps modul. ın hıper termınal looking some ccharacter.but dıdnt gps data. ıs the problem 5v-12v real serıal port voltaj.what you thing and sory bad englısh.
