USB to rs 232 Converter
sudeepb
Junior Member level 1
usb to rs232 schematic
Any body has USB to 232 converter circuit??.
usb rs232 schematic
I think you should consider to buy one already made.
They are extremely cheap and you will save your time for more useful things.
I use one from digitus (www.digitus.de) and I'm really satisfied with it
PicMan
    V
usb to rs232 converter schematic
Take a look at www.ftdichip.com.
they have a USB 2 serial IC and
a application note how to build a
USB 2 rs232 converter
    V
rs232 to usb circuit
You find the FTDI chips and eval boards in-stock at http://www.lawicel.com
lots of information: **broken link removed**
Have fun
/WD
usb to rs232 ic
Try Prolific USB to RS232 IC
I had tried the FTDI Chip and Prolific PL2303 ,
I think PL2303 much more better than FTDI (FT245BM , FT232BM),
it cheaper and easy to use , smaller size , much more easy to install the software.
PL2303 is the best choice for me, so try PL2303, you will like it.....
See ==> www.prolific.com.tw
usb to rs232 converter circuit
I have three questions about Prolific PL2303.
Do you know where to find application notes or sample schematics for Prolific PL2303?
I can only find the Prolific PL2303 datasheet: **broken link removed**
Is it possible to order samples of the PL2303?
Where can I buy this device whithin the EU?
Thanks in advance,
ME
rs232 to usb schematic
There was a design in dutch Elektor May 2003 using FTDI chips:
http://elektuur.o4s.com/Elektuur/NL/Products/Magazines.nsf/0/C92ECD5703AEF2EBC1256D160040D4C1/$File/020375-1.zip
cygnal cp2101
pls send shemas
rs232 to usb ic
usg01 said:
pls send shemas
Which schematic are you talking about?
Doesn't anybody have info about Prolific PL2303?
Where can I find application notes or sample schematics for Prolific PL2303?
Where can I buy this device?
Regards,
ME
digitus rs232 usb driver
Here are the Prolific RS232 to USB transfer IC
PL2303 and PL2313 Schematic files include ORCAD files and PDF files.
Just share with you, my friends.......
And I buy it in Taiwan , throught the Maxtek Technology Company
Hsinchu office
Tel: 886-3-5509778
fax: 886-3-5509770
www.maxtek-icrep.com.tw
pl2303hxd schematic
I use ready made US232 USB <> RS232 Converter cable, **broken link removed**
The circuit diagram is listed in the documentation
usb to rs232 schematics
Cssheu,
There is a RS232 level converter with inverters in your circuit. (SP213EH)
Does PL2303 work with inverted or non-inverted RS232 RXD and TXD signals?
It is described RI, DTR, RTS , CTS, DSR, CD signals are active-low but there is no information about RXD and TXD....
I am confused. Did you tested this schematic?
Regards
diy usb rs232 converter
Cygnal - CP2101: USB-to-UART Bridge (Unit Price: $5.70)
Features
• USB Spec 2.0 Compliant; Full-Speed (12 Mbps)
• Integrated 512B EEPROM for Vendor ID, etc.
• Integrated Transceiver; No External Resistors Required
• Integrated Clock; No External Crystal Required
• USB suspend supported via SUSPEND pins
• Event Character & Line Break Condition Support
• All Handshaking & Modem Interface Signals
• Data Formats: 8 bit; 1 or 2 Stop bits
• Parity: Odd, Even, No Parity
• Baud Rates: 300bps to 921.6kbps
• 512B Receive Buffer; 512B Transmit Buffer
• Hardware X-On / X-Off Handshaking
• 5x5mm MLP-28 Package; -40 to +85C
pl2303 application note
I bought a data cable from a street seller for my cellular phone.
It is a little box with a power LED. There is a small two sided PCB in it and it includes 25cm USB cable and 30cm cable to phone with a special phone battery-holder and pin type connector. There is a Prolific PL2303 in it.
And it is only 3 USD without haggle... I belive I would buy it cheaper but I was amazed of the price.
I think it comes from Far East or somewhere like that...
usb rs232 converter schematic
Cygnal VCP device drivers are required for CP2101 device operation and are only distributed as part of the CP2101EK evaluation kit. Therefore, a CP2101EK kit should be ordered before or at the time of the initial order of CP2101 devices.
Cost of Evaluation Kit CP2101 = $49.00
usb serial schematic
Have anyone ordered this kit or have the royalty free Virtual COM Port device drivers?
tusb3410 schematic
Sabakava:
What is the reference of your cellular phone?
data cable
there is no mark on the cable and box... I think it is a third party product... I'll but three data cables more to desolder PL2303s and use in my board... I draw ccsheu's PCB with MAX213.
digitus usb rs232 driver
hi
someone please clear the topic as i am unable to get a complete solution on it too..
is there any other described link ?
thanks
pl2303 circuit
Hi .. is any one try TUSB3410 from texas instrument. I look at datasheet and it Demo board ,It looking good and it seem to be easy to build. They also provide firmware and software driver for it But i haven't try it yet. Is ahny one have experience with this chip?
