USB Pic programmer problem
For the first time PIC18F2550 parallel port programming(firmware burn) which mode i will select from the hardware setting of winpic800 as shown in following figure(this mode or another mode?) for the above picture given for PIC18F2550 firmware burn(parallel mode). Suggest me....**broken link removed**
In that picture choose art2003 programmer.
someone have pickit3clone schematic?
I migrate from jdm to pcikit2clone i\'m happy how this works.
Yes, JDM is old but still in use, its good for usage over RS-232. PICKit2 have much better device support and capabilities. I switch from PICKit to MikroProg.
While Pickit 2 is connected to computer then its (PIC18F2550) get heated slightly. Is it normal or a problem? i checked many times but would not find any fault in IC output.
I didnt notice any heating on my PICKit 2 Clone. Now I using MikroProg as PIC programmer.
Check all connections and parts. Somewhere you drain more current than planned.
Check PCB on shortcircuit.
it works well but slightly heated. Is it ok?
