c_mitra
Advanced Member level 6
As I see it, it is used to load the oscillator to 50R, so that measurements are done with the oscillator loaded at 50R.
Then any voltage measurements with the 1M scope probe will actually refer to 50R.
Is that so confusing?
What I am saying is that if a commercial module is to be measured, there might be no need to put the 50R feed through resistor, because these modules are already matched to 50R, in other words their output impedances are 50R. So paraleling another 50R (the feed through) will give voltages at 25R load, not 50R.
Yes, it is *confusing*
Many power RF oscillators cannot work well without a load and if the power is *reflected back* to the circuit, there is often possibility of damage to critical components.
Most small signal (low power) RF oscillators will not work with a 50E load (because it will get overloaded) but that is a different story.
Any 50E load permanently connected to the circuit as a load is dissipative and simply *wastes energy*. The energy was meant to be delivered to somewhere else.
But anyway, commercial RF units are likely to have 50E input and output impedance at specified frequencies; they can be (*not always*) easily connected with another module with 50E input/output impedance. Impedance matching means input and output must be complementary (complex conjugate) and the reactance must balance out. But I do not see how that matter with a scope probe measurement of a voltage.
