Unbound Pin problem (Besoin d'aide)
plasma2000
Junior Member level 1
unbound pin
I have tried to draw a simple layout , no problem when I check it against source.
But when I do LVS, I found an "Unbound Pin error", I don't understand. Maybe it's the simulator's bug or sth else?
Thanks for your help! Merci.
unbound pin lvs
The LVS tool is not able to identify the 3 pins in layout, but is finding it in schematics. So check the properties of the pin, it should be the pin layer of the respective metal on which u are attaching the pin.
Also, LVS is locating the gnd pin, so u can compare the properties of gnd pin with the other pins.
Hope this is helpful to you..
lvs pin unbound error
I got it, thanks.
I had forgetten to change the properties of pins to "pn"
