solofrain
Junior Member level 1
I'm trying to build a circuit for ultrasound detection, and I'm asking for help to select ultrasonic transducers for it. The detailed requirements are:
. The distance between the transmitter and the receiver is approx. 30 ft.The transmitter should have low power consumption, so the receiver must have high sensitivity (-70 db minimum? I'm not sure).
. The receiver should be frequency selective (e.g. 40+/-0.1 KHz).
. The transmitter cannot be aligned with the receiver in real application.
. No data will be carried with the ultrasound. As long as it can be detected at the receiver side, that's OK.
Can somebody recommend ultrasound transducers that are OK for me? Thanks.
