Easy peasy
Advanced Member level 6
Faulty scope probes or "open ckt" gnd connections will not help in fault finding, hopefully your fet and driver and associated cktry have survived and you can check the transformer phasing
you can also run the ckt off a say, 24V, DC supply with a 1A current limit, and a 12V supply for the chip - this will allow you to play around and not damage things if you slip with a probe, or the Tx is horribly wrong ...
best of luck ...
best of luck ...
