jstefanop
Member level 2
- Joined
- Nov 9, 2011
- Messages
- 48
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,286
- Activity points
- 1,789
Making a precise logic comparator and regulated current limit is harder than it looks with a wide tolerance of hFE in an common emitter. So was never done that way in logic chips. None of these compare using a proper logic gate to drive the LED with a fixed current limiting R, which would be the best solution. (LVC type only)
Sorry to be harsh, but that's the reality.
I agree and understand, If i ever wanted to mass produce this I obviously would not go with this simple solution. Like you mentioned all I need is a fixed current limiting resistor to make this more reliable...so the question is do transistor packages exist that include a resistor in series with the emitter or collector line?
EDIT: Actually or an LED that has a current limiting resistor in a surface mount package?
