UART is displaying unexpected characters
I mean simple USB to serial converter which is just locally available one
Breakout board, Is this special kind of board
Currently I am using PuTTy for PC interface. If I used USB to serial converter then, can I use PuTTy ?
Yes, you should be able to use a commercially available USB to RS-232 serial converter/adapter.
And Yes, you shouldn't have any problems using the converter/adapter with Putty.
I regularly use such a configuration with Putty when developing embedded applications.
The only issues with some USB to RS-232 serial converter/adapter is many of the less expensive units do not offer all the lines required for full hardware handshaking.
As it appears you are not using hardware handshaking, it should be an issue even with the less expensive models.
BigDog
Reactions: PA3040
    PA3040
Be aware that there are 2 types of converters.
One converts the Pics Usart TTL signals to USB, the other takes the MAX232 chips / DB9 signals to USB.
Just search on Ebay for 'usb to serial converters' plenty for a couple of $
Reactions: PA3040
    PA3040
Dear wp100 thanks for help and reply
my hyper terminal display values continuously
Like this
2.23v 2.23v 2.23v 2.23v
but i need to display like this
2.23v
2.23v
2.23v
2.23v
cursor should reset to new line
please advice
Thanks in advance
Look up the " Ascii control codes " list, it shows all the normal ascii characters plus the 'control' ones such as CR and LF.
After sending the 'v' send out these two characters to move to a new line.
movlw 0x0D
call tx_rs232
movlw 0x0A
call tx_rs232
Reactions: PA3040
    PA3040
Dear All,
Now my USART is working well with PuTTy
Now what I need is , the data coming from MCU that need to be saved using spreed sheet or any other location
Please guide me.
Thanks in advance
You have to save the data as ascii text and then save the file with .csv file. The you can open .csv file in MS Excel.
If you save the below data in .txt file and then rename it to .csv file and then open it in excel the data will be tabulated.
DATA1, DATA2, DATA3
1000, 2000, 3000
10, 20, 30
Reactions: PA3040
    PA3040
Dear Jayanth,
Thanks for the reply.
Could you please advice, how may I do it automated
I mean, The data are receiving continuously to PuTTy, then I need to save those data automatically
Please advice
Thanks in advance
Is it possible
Dear Jayanath Thanks for the reply
Sorry for delay
1.Let me know the path of putty.log file
2. I supposed to connect LCD and 433Mhz RF Transmitter And Receiver to MCU
RC7 and RC6 (rx,tx) pins already connected to LCD
Now I need to connect 433 transmitter and receiver for the same pin which LCD connected
Can I do this implementation in practically and please any connectivity advice
Thanks in advance
