mtwieg
Advanced Member level 6
I added the current regulation circuitry, which seems to regulate the current just fine, but as I feared my gain is still drifting by almost -2dB, even with all the bias conditions fixed. So the S11 at least of the transistors is temperature dependent. I've found that removing my matching networks and just connecting everything directly improves things so I get a little less than -1dB of drift, but at the cost of about 10dB in overall gain...
I'm thinking that maybe if I use matching networks with broader bandwidth and more poles, the drift of the transistors' S parameters won't impact gain so much... does that even make sense?
