T
treez
Anyway, like you can see, i gave it an np/ns of 10....
so you can choose 60/6, or 120/12, etc etc
choose whatever number of turns you like , as long
as
1...you have the right np/ns
2...you have whole numbers of turns for np and ns
3....You dont dissipate too much in the wires of the coils
4...you dont overheat the core with core losses.
5....you dont saturate the core
6...the turns fit on the core
7...you can terminate the turns to the former
8...mind out for skin effect
So you could use a layer of approx 0.5mm wire for the pri if choosing 60 turns...
and then you could have a few parallel strands for the sec...and spiral wind them across the bobbin so that the turns are evenly spread across the bobbin..
..this tends to increase coupling between pri and sec.
If your number of tunrs is low, then you often have ti use paralle strands to get the coil layer to fit the bobbin width...but as discussed , you can always do spiral winding.
as
