twin well and triple well CMOS process
fanshuo
Full Member level 5
Full Member level 5
Netherlands
triple well
what are the differences in respect to performance?
triple well process
basically the substrate isolation. triple well transistors are more isolated.
khouly
    fanshuo
triple well cmos
yes, there is more isolation,I know that.
Is there anything more?
twin well process
i think the triple well is specially used for the RF transistors , which will be used in LNA and VCO and varactors , this is very important , maybe it has a relation with the substarte network in RF CMOS transistor model
khouly
twin well
Hi fanshuo,
Read this article hope this give you more idea about triple well performances.
triplewell
In general MOS devices have 4 terminals D G S B.
B terminal [Bulk/Substrate] has an important role in MOS functionality. From the back-side of a MOS the substrate potential can affect the channel characteristics - it resembles very similar functionality of a Gate terminal of a FET [not a MOSFET but, a Field Effect Transistor], it is called back-gate. You want finer control of the back-gate - go get a triple-well MOS.
We call them isolated-MOS too - the reason being - electrically isolating the bulk node from global substrates.
Although it is not mandatory to keep Source & Substrate connection of a MOS be shorted together, there are design requirements, where the S,B needs to be locally shorted - please note, I did not mention yet - S,B shorted to VDD or GND. Keep it at whatever different potential from global VDD/VSS you need a triple-well process.
Triple well further reduces signal and noise coupling to and from substrate [OK, same as noise isolation].
Triple well might help addressing different potential requirements at IO ESD regions.
Well, somewhere I might have read something about virtual power switching [power-gating] using back-gate [not sure].
All such things are possible by using triple well structures.
Reactions: garm and jlgr
    jlgr
    garm
twin well cmos
sat
You mean in triple well devices, it is possible to control bulk/substrate potential?
Because in most case it is not possible, you can only connect the substrate to ground
Added after 1 hours 15 minutes:
by the way, I found that it seems the triple well NMOS has better noise performance than its double well counterpart
triple-well process
triple well provide gud isolation ........ low noise substrate noise coupling.. and it is favourable for multiple ground circuits.....
triple well cmos process
Tripple would provide much better LATCH-UP protection over the TWIN well structure.Usually a extra deep N well is implemented underlying the P-Well or N-well, the minority carriers is collected by the reverse biased local (bulk-to-deep N well) junction.
