barf_soft said:
Its starting current is much higher because it is stalled and is just the resistance of its windings.barf_soft said:First I must tell that the current for dc motor in direct use in 5V is 100mA
hFE is used for a linear transistor that has plenty of Vce. When it is saturated it is spec'd with a base current that is 1/10th its collector current. Look at the datasheet for any transistor to see this.and the hfe for BD135 in 100mA is ~ 55
A darlington has 1.5V voltage loss and his supply is only 5V.hameeds01 said:y don't u use Darlington pair transistor like TIP 120 ??
