kathmandu
Full Member level 5
I'm building a sinewave inverter and I'm using a low frequency transformer at its output. As I need an isolated feedback signal to control the output voltage, I was wondering if I could make an extra winding (few turns) to get a proportional voltage.
The question is: will it be accurate enough? I mean, will it be proportional enough with the main secondary voltage (230V)? If the main load (output current) is changing (thus the main voltage will change too), will the feedback voltage closely follow the main voltage?
