mbyka
Full Member level 5
- Joined
- May 12, 2002
- Messages
- 297
- Helped
- 12
- Reputation
- 24
- Reaction score
- 10
- Trophy points
- 1,298
- Location
- from istanbul in TURKEY
- Activity points
- 2,107
I would like to introduce TFT Smart HMI LCDs, which I also used in my cosmetic medical device (laser epilation, skin care, permanent makeup, regional slimming, etc.) designs before I started selling them in Turkey and all over the world.
Programming and managing the screens is extremely simple and fast.
To manage/use the screens, you can make your own MCU cards with UART/TTL connection or PLCs (modbus RS-485) or PC/Laptop (RS232) connections.
For purchase price quotes, detailed technical information and programming assistance,
contact information:
onderkaman@dwin.com.cn
The information I share here includes a short preview.
Touch or Non-Touch TFT Smart HMI Displays 3.3V...36V, 2"...21.5" WI-FI, AIoT, Linux 4.4.1, Android, PLC RS485(MODBUS), Analog-Digital video, USB CAMERA, audio , gsm, Ethernet, UART TTL(max.16Mbs)-RS232-RS422, SD CARD
65K Color(16-bit)...16.7M/262K Color(24-bit/18-bit)
Resolution:
24240=240*240 32240=320*240 32320=320*320 48270=480*272 48320=480*320 48480=480*480 64360=640*360 64480=640*480 72720=720*720 80480=800*480 85480=854*480 80600=800*600 10600=1024*600 10768=1024*768 12480=1280*480 12720=1280*720 12800=1280*800 13768=1364*768 or 1366*768 16720=1620*720 19480 =1920*480 19108=1920*1080
Dimensions:
020=2.0 inch 024=2.4 inch 028=2.8 inch 030=3.0 inch 035=3.5 inch
040=4.0 inch 041=4.1 inch 043=4.3 inch 050=5.0 inch 056=5.6 inch 068=6.8 inch
070=7.0 inch 080=8.0 inch 088=8.8 inch 097=9.7 inch 101=10.1 inch 104=10.4 inch
116=11.6 inch 121=12.1 inch 150=15.0 inch 156=15.6 inch 185=18.5 inch 215=21.5 inch
Product type:
basic type
case base type
Analog video platform
System products (Android and Linux platform)
Digital video platform
LCD operating Temperature Rating:
"N": Normal Temperature "W": Wide Temperature
TP Category:
"N": Without Touch Panel "T": Touch Panel "TR": Resistance Touch Panel "TC": Capacitive Touch Panel
Extended Memory:
F0=512MB F1=1GB F2=2GB F3=3GB,
LED lifetime:
10,000 hours - 50,000 hours
Use CR3220 or CR1220 lithium electronic battery as RTC backup power source, battery life needs to be replaced after 1-5 years (depending on battery and usage environment).
Using Farad capacitors as RTC backup power supply, it can take about 30 days after power failure and no service life issues.
Internal NAND Flash memory 1Gbits (128Mbytes)....16Gbits (2Gbytes).
External SD Card 4-32(64)GB
3.3V-5V level, compatible with TTL/CMOS full-duplex UART interface, the highest speed is 16Mbps.
Resolution:
Dimensions:
Product type:
basic type
case base type
TP Category:
Extended Memory:
LED lifetime:
