KlausST
Advanced Member level 7
- Joined
- Apr 17, 2014
- Messages
- 26,307
- Helped
- 4,926
- Reputation
- 9,875
- Reaction score
- 5,797
- Trophy points
- 1,393
- Activity points
- 177,101
It's becoming an endless story.
Now that you put the pot after the buffer you have the already explained:
* volume control influences sound
* sound setup influences the volumes
Still missing one power supply capacitor.
The output resistor has nothing to do with pot noise, it's to compensate for stability issues caused by capacitive load (cable).
But I doubt the 10R is enough. Look into Opamp's datasheet.
Mind your junction dot issues.
Mind that the sound control circuit is inverting. This might cause problems in combination with other sound equippment.
Klaus
--> gain is 11I added a volume pot after the buffer OPAMP and then I added a gain of 10
Klaus
