JUN2
Newbie level 6
- Joined
- Dec 11, 2024
- Messages
- 13
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 83
Hi, i am using opto as an isloation between a three phase gate driver circuit and controller(signal generator), but i met a problem that is when i connect for example INH3 and INL3(also the ouputs from opto) the same time from opto board to the driver board,
and when i give INL (low side mosfet switching) signal, the Vgs of low side mosfet shows nothing, but once i unplugged the INH3 connection bwteen driver and opto, the there will be vgs waveform, the whole time i didn't give any siganl to INH3.
Also when i directly give INH or INL signal without the opto islation, the waveform is right, high side and low side mosfets are switching, the problem should not be driver circuit, i tried to use a seprate Vcc power supply, and also tried to seprate INH and INL opto on different pcb board, but the issue still there, i think it might becuase they shared the same ground, however they have to share the same ground of driver, so i just get stucked, anyone could help, thank you so much
