three noise maker, but different output offset
canlu
Junior Member level 1
hi.
i have this circuit with op37 op-amp, and repeated three time.
but at output i have different offset according to pictures:
every thig is same and resistor's are 1%.
even in the output i have mkt cap.
what can cause such behavier in this circuit?
Yes for sure, did not factor in Aol and Ioff, here is update (using parameterized OpAmp) :
Done of first stage last schematic.
Regards, Dana.
i'v been decreased R4 to 30K, so gain reduced to 30 and now feedback current is enough.
but i have output offset -2.6 ~ 6V.
And of course, when the input has an offset, the output will also have an offset too.
input and output signal of first stage:
now what?
thank's in advance🥹
I am thinking noise differences due to zener knee device to device
differences there is no "matching". Nothing in datasheet that gives
pk-pk min/max or its distribution. Its a statistical process, not deterministic.
As far as any other differences the 1 uF coupling cap tolerance and leakage
one part to another is poor. The tolerance is+/- 20%, so V divider effect
with 1 Mohm R will effect both offset and G in signal path. leakage can be
in uA range = volt(s) of offset due to 1Mohm, and bias current of OpAmp.
Regards, Dana.
maybe, i have different voltage across zener's (9.2 ~ 9.7)
but circuit have 1% resistor's.
however i expected after capacitor i have centered GND and but not with an offset.
i'll try decrease zener resistor (R1).
1more question:
i have op37 with +-15V supply
so output swing would be +-14V or a bit more...
but according to output i have +19 and -10V
what's happend here?
1more question:
I must not be following what you are doing, how do you get +19 out of
an OpAmp powered with +/- 15 ?
Regards, Dana.
LaTeX Commands Quick-Menu:
