third harmonic in sigma delta modulator's output spectrum
pankaj jha
Full Member level 3
Full Member level 3
jaipur
I am following the thesis " Look-ahead Sigma-Delta Modulation and its application to Super Audio CD".
In Chapter 2 (Basics of sigma-delta modulation) page 24 it is mentioned that -- "Typical distortion of an SDM consists of odd harmonic components, i.e. components at (2n + 1) · fin ." I can understand that since the quantizer is non-linear, making sigma delta modulator a non-linear system, odd harmonics prop in the spectrum of the modulator's output.
Can you suggest me the necessary papers/references which can provide me a detailed explanation of the above argument
There are different sources of non-linearity in a SD-modulator. The assumption, that you mainly see odd harmonics is of course based on prerequisites, generally speaking no even terms present in the polynomials describing the transfer characteristics of individual building blocks.
There's a paragraph about distortion in the simulation chapter of Nortsworthy, Schreier, Temes: Delta-Sigma Data Converters- Theory, Design and Simulation
Thanks FvM for the reference. Thanks a lot.
