yefj
Hello,I want to test the delay of a pulse when NPN is saturated and non saturated state.
I know it depends on the level of the pulse.
From the datasheet and abothe manual i have tried to recreate the state oj the junctions.
At first EB junction must be forward. I have tried to build the circuit below.
As you can see the BE junction is active,also you can see the Vce is very high.
Base current and collector current are attached.
How do i know if my NPN is saturated or active acording to the datasheet attached?
LTspice file is attached.
Datasheet for 2N2369 Motorola Transistors | Octopart
View and download the latest Motorola 2N2369 Transistors PDF Datasheet including technical specifications
octopart.com
