- Joined
- Jul 4, 2009
- Messages
- 16,623
- Helped
- 5,158
- Reputation
- 10,349
- Reaction score
- 5,240
- Trophy points
- 1,393
- Location
- Aberdyfi, West Wales, UK
- Activity points
- 140,647
Most of the problems were due to under-rated power supplies. You have to remember that in the 1980's consumer electronics boom, the markets were flooded with very low quality equipment that boasted specifications that were impossible to reach. There were no consumer protection laws in those days so a "Hi Fi" unit might have superb specifications but in reality be an under rated, badly designed, badly built cardboard PCB with 50mm bass speakers! If I remember correctly, one "20W per channel" system that passed through my repair workshop had a 1A rated mains transformer in it that also powered the receiver, cassette deck and record deck motors.
With 'noise' you have to be careful how you measure it. For example, 50mV of noise on a supply line might mean 50mV of noise across the loudspeaker but the same noise at the amplifier input would drive it into full power. Generally, the hiss kind of noise that increases with the volume control is generated in the pre-amplifier stages where the gain is normally much higher. It rarely originates in the power output stage. I have never seen any 'noise reduction' circuits in a power amplifier and usually by careful choice of components and gain distribution, it can be minimized in the earlier stages.
The LM1875 is almost a drop in replacement for the TD2030A but has much higher specifications. It is still in production and easily available. It's distortion specification is typically 50 times lower than the TDA.
Brian.
Brian.
