kbtan
Member level 2
I plan to do a circuit than will power up a LED for 5s after i press a button without using a microcontroller. Can any one give me a suggestion on how to design such a circuit???
ya i am using a 9 v battery. also have a 5v voltage regulatorAs FvM pointed it out; what is the power (voltage) supply of your circuit? Is it a battery
CD4011, Quad 2-Input NAND gate
or
CD4093, Quad 2-input Schmitt trigger NAND gate
Notes:
(1) I think you heard of "RS flip flop using two NAND gates".
(2) If your circuit is just about the LED, using a CMOS IC doesn't need a 5V regulator. 9V battery is ok.
(3) If your LED is red, by the same battery current 3 LEDs (or 4) in series could be turned on via a current limiting resistor.
(4) If the LED color is white or green, only 2 LEDs could be connected in series.
Sir i read the RS flip flop NAND gates from this site **broken link removed**Could you search for "RS flip flop NAND gates"?
When you will get it, we can talk about the next move
Sir I don quite understand this meaningIn the next steps, we will use another gate with an RC circuit at its input. Its ouput can reset the flip flop after a time delay (say 5 sec) if connected to the input R (pin 1).
Before further analysis, could you tell me if you can get the CD4011 IC and build the circuit?
WRONG: If you can build the circuit so far, you will notice that the output of U3 (pin 10 as pin 1) stays high for about 5 sec every time you briefly press the push-button PB1.
RIGHT: If you can build the circuit so far, you will notice that the output of U2 (pin 4 as pin 2) stays high for about 5 sec every time you briefly press the push-button PB1.
I am using a white LED.Before completing the design, could you tell me more abour your LED?
What is its color?
Is it rated for 20mA, for example?
In this case, the LED forward voltage is about 3.3 V
If you like we can put 2 LEDs in series... ok?
I assume it is a small (standard) LED hence rated @20 mA... right?
