banh
Advanced Member level 1
washer machine using microcontroller diagram
if an array of PIC, what kind of communication protocol can we use?
djalli said:one single PIC microcontroller is not enough. Overall you need an array of PIC's synchronized with each other in order to make it altogether work. The higher the frequency the better is it. Plus you need a large memory over 64-128kb attached in the chip.
Idea seems great, francky must yeild inexpensive solution to the problem and becomes better electronic household equipment.
