Substrate definition in ADS EM simulation
R.Maher
Newbie
Newbie level 3
Hello everyone,
I try to design an RF rectifier using ADS co-simulation. I am confused about the correct definition of the substrate.
I need to define the back side of the substrate as the ground. what is the correct way?
I defined two copper layers (on top and bottom of the dielectric), draw my layout on the top layer, draw a rectangular shape on the back side, and define this back conductor as the ground for the input port.
I used TML calibration for this input pin port only.
Are these steps correct to match measurements?
Also If get negative real impedance from the layout EM simulation (before connecting lumped elements for co-simulation),
What does this mean?
Thank you all and waiting for your help.
Solution
Yes, my layout is single sided so I will work with your answer. But if I want to draw a defected ground structure, how to define the substrate?
In that case, your approach above would be fine. Just make sure that your port references have some connection (same as in real world), so that current can flow.
Switch off port calibration in that case, this should solve your unphysical result issue.
Be careful with port grounds: current can only flow in closed loops. If your DC load uses another port ground conductor than the RF input port, simulation will fail.
If your layout is essentially single sided, with all the backside as one large ground, you can use an infinite ground boundary in Momentum stackup (see pictue). That is recognized by Momentum as the default (implicit) ground reference for all ports.
Regarding port calibration, TML seems to fail on your port 1. Most likely that is because you have specified cond2 for ground and there is no cond2 ground drawn below the calibration line. For this explicit (drawn) ground layer, I would switch off TML port cal. If you use the infinite ground boundary instead, TML cal should work fine.
Thank you for your help and explanation.
The reference point for the RF input is under the input line. For the DC load, there is a via to the ground layer and it is the DC ground reference.
Solution
