Cluricaun
Advanced Member level 2
Hi
I do not know if it is possible or helps to change or delete any file but several tweak SW can change. I think you can change some of the info without special SW but reccomend to try X-setup from www.xteq.com/
After you have installed the SW you find the info here : System-User Data
For security reasons it is always good to use a firewall, even so with EDA SW...
