asp87
Junior Member level 1
I have some basic doubts regarding voltage follower configuration.
1. In the circuit diagram shown, the A+ input gets 4.87V. Since it's a voltage follower, output should also be 4.87V. Instead, it's 4.99V. Why is it so? I need to use this circuit to buffer a signal to the input channel of an ADC and hence want the voltage to be precise.
2. Is this the proper connection for a dual power supply opamp? In this circuit the opamp is not connected to ground anywhere.
Please clarify.
Please clarify.
