Software protection on a flash of Motorola 68376 CPU
Re: Software protection
As an expansion to coldfire :
Use the public-key encryption algorithm (you can found it wildly on the net ) one part of the key will be burned on the flash (public part) and the second part will be located on the secured UC combining both part will give the decryption key for the contect of the Flash rom
best
bobi
Hmm, and where is decryption routine or decryption hardware?
Decryption routine and 2nd part of public key will be located on the secure slave controller
the main processor get data from the Flash memory send it to the secure slave controller decrypt it and place it back in ram location
the software can then set a ptr to the ram location and run the the program or part of it (for intance data table) from the new location
best bobi
heh, and data between CPU and slave controller is unencrypted??? How about sniff all data exchange between them?
here is a sample
hi:elektryk
The encrypted data could change everytime, and need a very long time to repeat, maybe one or two month. It is depent on you encrypt algorithm.
