T
treez
Hi
In the graph of SOA in the SPB07N60C3 FET datasheet (pg 5), i presume the "DC" means "duty cycled", or "Direct Current"...in other words "pulse trains" or continuous DC?
The "tp" obviously stands for one-off pulses....its surprising how low these are....you wouldnt think the FET (especially if well heat-sunk) could suffer damage in such a short space of time especially if well heat-sunk so its temperature did not rise significantly during the one-off pulse?
https://www.infineon.com/dgdl/SPB07...90004&fileId=db3a304412b407950112b42df065491f
Alos, why is the SOA graph only given for T(case) = 25degC?....this is surely unlikely, do you know how we can get a SOA graph for T(case) = 80degC?
