SIP Network Active Speaker
sinrey
Junior Member level 3
SIP741V is a wall-mounted SIP network active speaker with 10/100M Ethernet interface, which can play network audio sources through its own amplifier and speaker outputs up to 15W of power, and an external 15W sub-speaker (to be purchased separately). It supports setting up to 10 multicast zones with priority.
As a SIP playback terminal, SIP741V has only decoding playback function, supporting G.722, G.711A/U and MP3 audio decoding. It is a simple SIP active speaker with amplifier output, which receives audio data from the network and provides audio output.
Features
— Support SIP v1 (RFC2543), v2 (RFC3261) and Other network protocols
— Supports audio decoding protocols such as wideband G.722, narrowband G.711a/u and MP3.
— Accept SIP server center multicast data, with its own amplifier and speaker output playback
— Can be used with SIP803T intercom broadcast microphone, compatible with Other SIP decoding terminal, free to choose to build a simple SIP system
— Support RTP multicast protocol and private broadcast protocol, which can be operated by our broadcast software such as broadcast shouting and timed ringing.
