SIP audio module intercom broadcast pcb module with 2*15W Power Amplifier Supporting OEM
sinrey
Junior Member level 3
Audio Module SIP2401V Broadcast Intercom Help Audio Module PCB with 2*15W Power Amplifier Supporting OEM
Sinrey's SIP2401V network audio module is a general independent SIP audio function module, which can be easily embedded into OEM products. The module encodes and decodes SIP protocol and RTP audio stream from the network.
The module supports a variety of network protocols and audio codec protocols, and can be used for VoIP and IP paging, high-quality
music streaming media playback and other applications.
