SIM900 Customer Flash Loader
I have some firmware files which are attached but no longer have the USB uploader.
Please note that I do not represent Simcom and I am unable to provide any technical information or assistance.
Hi
I have bought development board based on SIM900, but program for SIM900 micro controller seems to have a lot of bugs and I can't finish my project based on this board (my project is SIM card tester based on arduino Duemilanove + SIM900 - but after changing one SIM card to another, SIM900 sometimes needs few restarts before SIM card can register to the network)
So i want to ask you for latest version of firmaware and loader for firmware for SIM900.
This is what AT+GSV command gives:
SIMCOM_Ltd
SIMCOM_SIM900
Revision:1137B01SIM900M64_ST_ENHANCE_Jablotron
  • sim900.zip
Hi
FW update doesn't solve my problem but SIM900 seems to work faster with new FW. Thank you very much for your help - this FW file is almost immposible to find.
can anyone provide me the latest firmware of sim900d
i am using this versions
SIMCOM_Ltd
SIMCOM_SIM900D
Revision:1137B09SIM900D64_ST
i am following SIM900_Email_AT Command Manual_V1.02 manual bit on each email AT command it give me a error
i think i need a firmware upgradation
I have downloaded 1137B07SIM900A32_ST firmware but after upgrading in com port am receiving only IIIIIIIII like that what is the reason for that plz help me..
Thank you in advance.
Hi all,
I'm looking for the latest firmware for sim900 and flash tool.
Can some one pleas upload it?
Best regards.
Hi all,
I am testing HTTPS application on SIM900, but its firmware doesn't support HTTPS AT commands.
Could anyone provide the latest firmware version for supporting HTTPS stacks in sim900. From where can we download them. has anyone got https data transfer successful with sim900 modems?
Regards,
jebin
Hello everyone,
Chipseller - could you please post the newest firmware for 900D?
Thanks in advance and best regards
Wojtek
Hello everyone,
Wojtek
I have shared the very latest firmware for SIM900 along with its Release Notes in this Post (1137B03SIM900M64_ST_ENHANCE)
SIMCOM_Ltd
SIMCOM_SIM900D
For email use the Enhance version firmwares. I have made a collection of all firmwares I have on my blog . Check them!
Hi
SIMCOM_Ltd
SIMCOM_SIM900
The latest version is 1137B03SIM900M64_ST_ENHANCE for SIM900
  • 1137B01SIM900D64_ST_ENHANCE.zip
hello everyone
I am using SIM900A. I want to send email for that I am using SMTP protocol.But after AT+SMTPSEND command i get +SMTPSEND: 65 ,somtimes 61 and 63.
Plz help me.It is urgent.
Hello everybody
Iban
Hello Iban and Sherazi
I hope you are doing good with SIM908. This time I have noticed a very surprising thing from my SIM900. I have been working on it over year but never noticed that. I recently found that while flashing SIM900 core firmware, it is overwriting the IMEI# of module to some random different no. It occurs when you load the EAT-firmwares on a new module. Modules are very much working and connecting network, but all of them has same IMEI#, which is point of concern. We tried to reload general firmware to check if it get back the actual IMEI# printer on modules, but it is a negative. I also tried to load EAT firmware on a new SIM908 module to check if it overwrite the actual IMEI# and it did, the IEMI# got changed/overwrote by loading EAT firmware. Unfortunately I didn't find any solution to this issue till now. Also did not find any way to rewrite the IMEI#.
So check your devices or module if you noticed the same issue.
-CND
For my SIM900A I use-1137B09SIM900B32_ST!!!
Works great with European networks!!!
Thank you very much you saved me many problems, the store in aliexpress sent me sim900A instead of SIM900. Even I killed one unit flashing it with 1137B09SIM900B32_ST, I didn't notice that my modules were 64_ST.
Regards
-CND
Just use this command to reload the original IMEI:
AT+SIMEI="your imei"
Reactions: cnd
    cnd
any sucess???
Any help for the comunnity??
Thanks a lot
Hi everybody,
Has anyone finally got work the SIM900 EAT or SIM908 EAT with GCC compiler instead RVCT2.2_616 version?.
If someone has had success making it, please post the procedure to make this working in GCC Compiler.
Regards,
Ignacio
Hello
Does any one has SIM900_AT Command Manual_V1.09.pdf and SIM900_Hardware Design_V2.05.pdf ?? Please share with community .
Hello
Did you googled? you can find it in first link simcom.ee site.
Regards
Regards
YES I JUST FOUND IT FROM THE ABOVE LINK AFTER POSTING HERE. THANKS ANYWAYS :smile:
Thank you Kosh, you have just helped me to solve a months long issue. I have used this AT command before, but my syntax was wrong. It is very important to put 15 digit IMEI # in double quote, i.e "IMEI#" SIM900 Module. I will check with SIM900A module later.
Imei Overwrite.JPG .
Hi!!
I'm getting this error (see image) while downloading the fw to a SIM900
I'm using an Arduino Nano to send the fw, directly connected to the Tx and Rx of SIM900 Shield as some tutorials over the internet say, but no success...
Any help??
Hi, I'm trying to update the Firmware of a SIM900 and I get the following error message.
Does anybody has an idea of what could be wrong ?
Thanks
