kopecdav
Newbie level 1
Iam triing to integrate SIM800C24 into our hardware design. Almost everything works well.
I was able to communicate the device over AT commands, I succesfully connected to a network and initialize a PDP context.
problem comes when i try to connect device over PPP protocol with command AT+CGDATA="PPP",1 (or ATD*99#)
The device respond as "CONNECTED" but imidiatelly after that start to blink fast with the netwrok LED and returns the message "Failed to create the dial"
I have tried to flash a latest firmware, check the power supply and anntena signal and everything seems to be ok, I can easily send SMS (phone call i cant try since is disabled on my SIM card).
does anybody know what is the cause of this issue?
Thank you very much ! and iam adding the sequence of used AT commands and responses
Log from serial terminal
AT
OK
AT+CPIN?
AT+CPIN?
+CPIN: READY
OK
AT+CREG=2
AT+CREG=2
OK
AT+CGREG=2
AT+CGREG=2
OK
AT+CGDCONT=1,"IP","TM"
OK
AT+CGATT?
AT+CGATT?
+CGATT: 1
OK
AT+CSQ?
AT+CSQ?
ERROR
AT+CSQ
AT+CSQ
+CSQ: 20,0
OK
AT+CGDATA="PPP",1
AT+CGDATA="PPP",1
CONNECT
[00][00][00][00][00][00]RichEd32.dll[00]Failed to create the dia[00][00][00][00][00][00]RichEd32.dll[00]Failed to create the dia
AT
OK
AT+CPIN?
AT+CPIN?
+CPIN: READY
OK
AT+CREG=2
AT+CREG=2
OK
AT+CGREG=2
AT+CGREG=2
OK
OK
AT+CGATT?
AT+CGATT?
+CGATT: 1
OK
AT+CSQ?
AT+CSQ?
ERROR
AT+CSQ
AT+CSQ
+CSQ: 20,0
OK
AT+CGDATA="PPP",1
AT+CGDATA="PPP",1
CONNECT
