Sim7000 http /TCP Connection fail
FeliSteck
Newbie
Newbie level 2
Hello guys,
I am currently working on a project using a simcom Module to send and recieve data from a firebase database via http requests.
I am currently at the point that most things i try with at commands are working. I got it to send an sms to my phone. But as soon as
I try something regarding http requests. It doesnt work.
The last thing i tried is this
AT+CFUN=1,1 // Reboot module
AT+CPIN? // Ensure SIM is ready
AT+CSQ // Signal strength (must be >10)
AT+CREG? // Network registration
AT+CGDCONT=1,"IP","apn" // Set APN
AT+CGACT=1,1 // Activate PDP context
AT+CIPSTART="TCP","google.com",80 // Test connection
OK //response
STATE: PDP DEACT //response
CONNECT FAIL //response
I also tried
AT+CGACT=1,1
OK
AT+HTTPINIT
OK
AT+HTTPPARA="URL","http://httpbin.org/put"
OK
AT+HTTPPARA="CONTENT","application/json"
OK
AT+HTTPPARA="CID",1
OK
AT+HTTPDATA=15,10000
DOWNLOAD
//Here i should be able to enter text/ key value pairs but it doesnt work
OK
I dont know what to do anymore, maybee someone here has an example walkthrough code or some suggestion or thing i could try.
I would greatly apreciate your help.
Thanks in advance Felix Steck
Try the following sequence of AT commands:
AT+CFUN=1,1 // Restart module
AT+CPIN? // Ensure SIM is ready (should return "READY")
AT+CSQ // Check signal quality (must be >10)
AT+CREG? // Check network registration (should return 1 or 5)
AT+CGATT=1 // Attach to GPRS
AT+CGDCONT=1,"IP","your_apn" // Replace 'your_apn' with correct APN
AT+COPS? // Check the registered network
AT+CIPSTATUS // Check current IP connection status
AT+CIFSR // Get local IP address (should return an IP)
If the AT+CGACT=1,1 fails, you likely have an incorrect APN or network issue.
Double-check your APN with your mobile provider.
Lack of CODE or SYNTAX Tags: Added by moderator
Thanks for your fast response,
I tried it and I get this in return, I dont really know what the response to CIPSTATUS means and CIFSR returns an error
AT+CPIN?
+CPIN: READY
OK
AT+CSQ
+CSQ: 21,99
OK
AT+CREG?
+CREG: 0,5
OK
AT+CGATT=1
OK
AT+CGDCONT=1,"IP","hologram"
OK
AT+CGACT=1,1
OK
AT+COPS?
+COPS: 0,0,"vodafone IT Hologram",3
OK
AT+CIPSTATUS
OK
STATE: IP INITIAL
AT+CIFSR
ERROR
Write your reply...
LaTeX Commands Quick-Menu:
