eem2am
Banned
Hello
We have two 7W Hysteretic Buck Converter LED drivers runing next to each other on a small PCB.
(LED load in each case = 24V, 330mA)
(Switching frequency ~ 200KHz for each LED Driver)
-Each LED Driver uses the LM3404 Hysteretic LED Driver IC.
-Each of these Bucks has a local 1uF ceramic input capacitor placed near to it.
V(in) = 30V = Secondary Rail of an offline flyback.
The flyback secondary capacitor is a 330uF Electrolytic and is about 4.5cm away from the two Buck LED Drivers.
Anyway, the problem is that the two LED Drivers, despite each having their own input capacitor, they pull some of their current from the neighbouring input capacitor aswell. (and probably pull some current from the 330uF ceramic capacitor aswell).
-Anyway, because i cannot have the individual input capacitors very near to BOTH of the converters, the pulling of some current from the neighbouring 1uF capacitor distorts the current sense signal at the other converter.
(due to the pulse currents flowing through the ground)
-The effect is worse for LED Channel 1 than for LED channel 2.
This results in distorted inductor and LED current
Here is the distorted inductor current in Channel 1:-
http://i46.tinypic.com/b7cumb.jpg
Here is a widened time-base view of the distorted inductor current:-
http://i45.tinypic.com/5ltd35.jpg
Do you know what i can do to stop these side-by-side LED Drivers from interfering with each other in this way.
The PCB is only small (3cm by 13cm) and there is not much , if any room for too many more components.
