should this generate square waves?
Girly_girl
Full Member level 2
UK
dear all,
1- i have been trying to run and produce a square waves using blockset in matlab..
i have uploaded the block..is this correct?
2- what is the initial seed ? it seems to be required in every block..
thanks
1. square waves? Nope, that wont generate square waves
2. initial seed is a random number that defines the generation pattern of the data. It is random so you can use any seed you like. It would not make a difference
Many thanks for your reply..
Could you possibly suggest me a block or a method to creat square waves?
Thank you so much
