Short circuit in a Switched power supply /charger
Hello,
If I measure on the copper shield of the transformer (se picture above) , after 30 min the temperature is about 50 Deg C, but I suspect it is higher when the power supply is boxed in it Alu encloser . may be that is ok, not sure. The charger charges a Nicd 12V battery at 16V 400mh according to the manual.
--- Updated ---
Now had gone about 2 hours , stablizes at 51 Deg C. In the closed aluminium encloser , there are no fans or vents...
How hot can these types for transformers will get?
I started another thread on that particular issue :
"How hot can the flyback transformer core on a 60 Watts SMPS be ?"​
Bad idea. Forum rules suggest to post similar questions in one thread.
