BiNa2605
Full Member level 3
I guess without the 1k load resistor in your original schematic?When I did experiment with the commercial board (P1110 from Powercast) the distance is over 6m and the output voltage is around 1.6V.
I measured the voltage at the output of load (LED and Resistor 2Ohm in serial- because the output current is so small) and in that distance the LED is still bright. In my understanding, Sir means I should measure the output voltage with series resistor 1k-5k at the rectifier to have the exactly result.
