bibo1978
Full Member level 4
Re: Ethernet with FPGA
ok then run your board in promocious mode, i.e. don't drop wrong MAC addresses and put some of the undefined packets on the block RAM or on an extrenal RAM "which is better and will allow u to monitor more of this data".
afterwards you can read the data, this way you will need a PC to board controller mean of connection, rs232 can do this, u read out the data in the ram and analyze it,
An easier way is to put the data on the bram and use the BSCAN to read the BRAM using JTAG connection, this way you may monitor a small time traffic.
