set up and hold time, transisitor level - explanation needed
sfriwblcii
Newbie level 5
Newbie level 5
why is set up and hold time needed ...Can anyone explain at the transisitor level as in where is this time needed going at the cmos level..is it some cap which is needing or is it some delay which is coming .....
Re: set up and hold time
plz find the attached slide...this explains what is setup and hold time.
it relies to the reliability of the circuit
@ shiva thanx for the pdf..... Can i find something more detailed anywhere
GO through this book attached
Static Timing Analysis for Nanometer Designs by J. Bhasker • Rakesh Chadha
cheers
Re: set up and hold time, transisitor level - explanation ne
Very good document ! STA.rar !
Its a must read for everyone who is interested in STA
@ research_vlsi
The STA Docs is really nice and would be very useful for everone
Muthamil
there are two video lectures here (i'm sorry i don't remember which ones, but they are near the end of the course) that explain timing and where setup/hold numbers come from. it is interesting to learn that of course setup and hold times are not some specific magic numbers but lie on a continuum of possibilities.
https://webcast.berkeley.edu/course_details_new.php?seriesid=2009-D-25491&semesterid=2009-D
cheers
Thanks for the book.. Its really a must read book for every vlsi engineer..Thanks for posting.. Keep on ticking..
One way to design flops is to use pass-gates to sample the D-input signal.
The pass-gate is controlled by clk and clkb.
You do not want the signal that is going through the pass-gate to be changing when the clock turns the pass-gate off.
If the signal is changing while the pass-gate is switching, what value is being passed to the MASTER latch? Who knows...could be 1, 0, or mid-level (bad).
So, to ensure this never happens timing checks are put in the simulation and sta models.
cheers
says file is corrupt.. can some one please upload it again please....
Good book. Thanks a lot for adding it here.
I am able to download it
